High temp readings and fan speed
Greg
Greg Member ✭✭
edited April 2017 in SmartSDR for Windows
I have a support ticket still pending on this. Has anyone else been experiencing hi temp readings and fan speeds when first starting the radio (6700)? DDUtil reports up to 165 degrees and stays like that for about 5 min then goes down to 30 degrees and the fans slow down. The radio is not getting hot during this and is happening just in RX...I am not transmitting. It does not happen all the time. Thanks Greg
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited April 2017
    Hi Greg, i never hear a fan speed of the my F6700, where you are saw this in DDUtuil 165 ?
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    Temp display in DDUtil. Regards, Al / NN4ZZ
  • Greg
    Greg Member ✭✭
    edited October 2013
    Yup....that be the place. :) Curious though that on the setup screen for the 6000 tab there is a space for PA temp but it doesn't report anything there.
  • Sergey R5AU
    edited April 2017
    Hi Al, thank you for update, on my toy this is: BTW firstly i think about other DDUtil page, where PA temp what is always still missing Greg, at one side you right, but in other way around do we really need this information, how it can help for user? Just my opinion for now
  • Greg
    Greg Member ✭✭
    edited October 2013
    Hi Sergey. I think it is always a wise consideration to keep an eye on the radio's internal temperature. If I see it go above 60 I know to give it a rest, see what's wrong that is causing the high temp, reduce power...etc. 73 Greg
  • Sergey R5AU
    edited April 2017
    Well, it is good, but this mostly the way to lost concentration on main functions in case allocation this on front page, but well appreciated somewhere in hidden menu
  • Greg
    Greg Member ✭✭
    edited October 2013
    No hidden menu. It is displayed on the main DDUtil screen. I keep that open below the SSDR window and just take a cursory glance at it now and then while I look at the screen or while transmitting. Not a distraction at all.
  • Sergey R5AU
    edited April 2017
    i get it Greg, good, on my screen DDUtil always hidden but provide a multiple service as well :-)
  • Al_NN4ZZ
    Al_NN4ZZ Member ✭✭✭
    edited March 2017
    This would be nice...... Regards, Al / NN4ZZ
  • Greg
    Greg Member ✭✭
    edited April 2017
    I think you need a second monitor... :)
  • Sergey R5AU
    edited July 2018
    or may be like this:
  • Sergey R5AU
    edited July 2018
    27 inch enough for now :-)
  • Ken W9IE
    Ken W9IE Member ✭✭
    edited December 2016
    I like that way Al, Looks Good Ken W9IE
    edited March 2017
    I have closed this topic because a HelpDesk ticket has been opened. If you are experiencing erratic or exceptionally high temperature readings, please open a HelpDesk ticket for resolution.
