SmartSdr Cat Should not depend on finding a 6xxx radio
Steven Greenbaum
I have both a 5000 and 6500 and use them both for digital modes. I was hoping that I could do away with vspmgr for creating virtual com ports, but since the com ports created by SmartSdr Cat are only created when a 6xxx radio is found it adds an extra step to setting up my 5000 and if the 6xxx is down makes setting up com ports impossible. I would suggest that SmartSdr Cat should create any port pairs not dependent on the 6xxx radio when it is started, and if a 6xxx radio is found at startup or later create the additional ports. At this moment I will have to keep using vspmgr so I can have ports independent of the 6xxx being powered up. Thanks..... Steve
Vspmgr seems to work well with DDutil Vs. 3 with both the 5000 and 6000. So until SmartCat becomes independent, you should be OK.0
SmartSDR CAT is so easy to use and configure, I would love to be able to use it with my Flex-6500 when I am not using my 6500.0
- 338 Community Topics
- 580 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 387 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 891 Maestro
- 50 FlexControl
- 849 Genius Products
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
