SmartSdr Cat Should not depend on finding a 6xxx radio
Steven Greenbaum
Steven Greenbaum Member ✭✭
I have both a 5000 and 6500 and use them both for digital modes. I was hoping that I could do away with vspmgr for creating virtual com ports, but since the com ports created by SmartSdr Cat are only created when a 6xxx radio is found it adds an extra step to setting up my 5000 and if the 6xxx is down makes setting up com ports impossible. I would suggest that SmartSdr Cat should create any port pairs not dependent on the 6xxx radio when it is started, and if a 6xxx radio is found at startup or later create the additional ports. At this moment I will have to keep using vspmgr so I can have ports independent of the 6xxx being powered up. Thanks..... Steve
  • Ned K1NJ
    Ned K1NJ Member ✭✭
    edited February 2017
    Vspmgr seems to work well with DDutil Vs. 3 with both the 5000 and 6000. So until SmartCat becomes independent, you should be OK.
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    SmartSDR CAT is so easy to use and configure, I would love to be able to use it with my Flex-6500 when I am not using my 6500.
