ACC Cable Commercially Available?
+Like0
Yes I thinks someone should make it0
As reported elsewhere many of us are using the nifty Winford DB-15 break out boards: http://www.winford.com/products/brksd15hd.php Winford has high quality data sheets and the product is about $15.00 plus $6.00 for USPS Priority Mail shipping. If you order 2 the shipping price is still $6.00. If you go with this slim breakout board you want the **** jack version. The non-slim breakout boards will interfere with adjacent connections but the slim version plugs into the back nicely. I wish these had been around for all of the DB-9 and DB-15 connectors I soldered over the years. An octopus may fit your needs better but the Winford breakout board is worth a look. Reg, KD5RB1
Making your own cable is not hard. The parts are cheap. Why not take this as an opportunity to apply some of the knowledge you have gained as a ham radio operator to carry on the time-honored tradition of building your own gear? If you aren't comfortable with soldering, I'm sure there's someone in your local club who would be glad to help out. I built my own interface cable for my SignaLink USB for $5, AND I have the satisfaction of having made it myself. Don't be an appliance operator, pick up a soldering iron!1
agree !! love the smell of melting flux...ha 730
or, if you're REALLY lazy, like me, you could sacrifice an old vga video cable? not sure if gender is correct, though...0
got FLDigi working via CAT , works good now0
I tried that with an old VGA cable I had, now that was a pain in the **** to ring out. Wires extreeeeemly tiny too. I ended up buying a new HD-15 and sacrificing a network cable to make it work. Here's the other advantage with BYOC (build your own cable): you can come up with nifty-non standard wiring to match your other gear. With the SignaLink USB, when you change rigs you have to change the internal jumpers. I wired my cable for the Flex to match what the SignaLink wants to see when I use my IC-706MIIG. Now I can switch rigs and I don't have to switch internal jumpers.0
*** CAUTION *** The VGA cable I checked had common wires that could be detrimental to the radio. I used a solder type DB connector and an Ethernet cable. The middle row on the DB connector was not easy to get right. I can see how this could be a problem for people with vision or dexterity limitations. I would recommend an DB 15 male to RJ45 female adapter: http://goo.gl/PXm7et Then just use a regular Ethernet cable. The cable is practically made for you.0
pin 11, TX OUT, would not be available, if you happen to need it with the adapter.0
Yes, I meant to point out a High Density 15-pin D-sub male plugable connector to RJ 45 adapter. This is a hard adapter to find.0
I don't think the audio is coming through the CAT.0
- 636 The Flea Market
- 144 SmartSDR+
- 431 SmartSDR for Mac
- 261 SmartSDR CAT
- 200 DAX
- 46 Aurora
- 958 Maestro
- 57 FlexControl
- 932 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
