SmartSDR Locks Up
DonS
Member ✭✭✭
If I open two slice receivers on a single slice with one (B) at 7.020mhz and the other (A) at 7.170 mhz and set the first to cw and the second to lsb then go in and adjust the AGC-T and set (B) active and enable TX and then return to (A) none of the options work on the (A) receiver other than making it the active receiver. I have reproduced this each time I try it. If I **** the (A) slice receiver I lose both receivers. I am able to reactivate the slice rx most of the time otherwise I have to power down SmartSDR and do the same with the 6700. I am using 16.4 running on an iMAC with Parallels using Win 7 Pro.
I should add that for whatever reason cw would not work with the external keyer after the SmartSDR locked up. It was almost as if the system ignored that input, when Iambic was non-selected, however, it did work with the key plugged directly into the key jack and Iambic enabled.0
Don, I have added this to the developer's bug tracker for further investigation.0
Is this still happening after an upgrade to SmartSDR v1.0.0?0
After I set it up as described in the previous message and go back to the A slice everything is frozen. I can enable the A slice, however everything else is locked. I cannot enable TX on A. I did have speaker selected on A so I see the AGC-T, etc but cannot change any settings. The only thing that seems to work is that I can select the blue Ant 1 and get the drop down and change it and change it back.0
If I change the frequency on the A slice by double clicking to a new frequency then the A slice control becomes active again until I go back to the B slice and then return back to the A slice then the A slice freezes up again.0
If I **** the A slice, it also kills the B slice so when I start a new slice it comes back as the A slice then I start a second slice and I get the same problem as I previously described.0
V1.0.00
Don, I have confirmed this a a software defect and have entered it into our bug tracker for resolution. This was a good catch! Thanks for the feedback.0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 331 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 776 Maestro
- 42 FlexControl
- 730 Genius Products
- 253 Tuner Genius XL
- 85 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
