can you change the baud rate on the 6500 from 9600 bd? If so, where?
Reggie-k6xr
Reggie-k6xr Member ✭✭
edited April 2020 in SmartSDR for Windows
  • Robert -- N5IKD
    Robert -- N5IKD Member ✭✭
    edited March 2015
    From the SmartCAT User Guide: 4.1.2 Configuration There are no user configurable tasks for using the integrated virtual serial ports other than the ones described above in the Serial Ports tab. The exposed virtual serial port can accept any baud rate, number of data bits, stop bits or parity configuration. In addition you can set the serial port flow control on the third-party CAT enabled program to any setting, as the virtual serial port driver will automatically configure the necessary flow control responses.
  • Reggie-k6xr
    edited April 2020
    Thank you for the quick answer!
