can you change the baud rate on the 6500 from 9600 bd? If so, where?
Reggie-k6xr
From the SmartCAT User Guide: 4.1.2 Configuration There are no user configurable tasks for using the integrated virtual serial ports other than the ones described above in the Serial Ports tab. The exposed virtual serial port can accept any baud rate, number of data bits, stop bits or parity configuration. In addition you can set the serial port flow control on the third-party CAT enabled program to any setting, as the virtual serial port driver will automatically configure the necessary flow control responses.1
Thank you for the quick answer!0
- 685 The Flea Market
