VOX
W4CCW
I just installed v0.16.4 and I do not see any VOX controls. What am I missing? Craig W4CCW
Try maximizing SmartSDR. If you don't see it at the bottom of the transmit pane, then try adjusting your screen resolution to something bigger. Mine works at 1920 x 1080, but some laptops and older PC's may have trouble getting a resolution large enough to reveal the VOX settings.0
yes you can drag the panels around, but you have to see them first. This is not a problem on my desktop computer, but probably will be an issue on the laptop.0
We are considering ways to improve the layout with dual purpose space. More to follow.0
Robert, agree, dragging only works if you can see at least a little of the panel to grab it. Dynamic panels are always difficult especially when you are trying to support multiple display resolutions. Regards, Al / NN4ZZ0
When the new version came up I don't recall seeing the controls. However, when I closed the transmit screen that had come up initially and then brought up again with the icon in the lower left I found the controls and tried them out. They worked quite well with my Heil 781, but there does not appear to be any anti-VOX to cancel the audio from my speakers. This limits my use of VOX to either very low level speaker output or phones. I'm sure I've missed setting up anti-VOX somewhere, but so far I've not found any mention in the release notes.0
