radio crashed
Greg
Today after finally getting a GPSDO lock I let the radio run for a few hours. Came out to the shack after dinner and as soon as I turned the flex control knob the radio froze and no more audio. I closed SSDR and restarted it and nothing on the display and then an error message saying connection to the radio was lost. Next step to turn off the radio which is in a solid blue LED state. Tapping the button cleared the display of Flex 6700 but did not say shutting down. THen by itself it went to solid green (i think) and then Flex 6700 came back on the display for about a minute then the radio just turned off. When the radio does not shutdown properly when it does turn off I again hear the GPS pulsing in the connected speakers that was thought to have been fixed in this latest version. Same pulsing sound. I will have to remove power and power it back up to bring it back. Done with it tonight. 73 Greg
Greg, Completely remove the DC from the radio for at least 30 seconds, re-apply power and see if it restarts normally, then try SmartSDR.. Hopefully this will correct the issue.0
OK Dudley...will try this tonight after work. I just got totally frustrated yesterday and needed to stop and leave it alone for the rest of the night.0
Dudley. I disconnected power and left it for about 10 minutes while I went and did something else. Reconnected power and since then things seem OK. I don't think I notice any raspy CW sidetone and while it took a little while for the GPS to lock, it did. I am using the marine GPS antenna with a different pigtail as well. Not sure if that is what improved the operation or if it was the long shut down. When I shut down it did so normally. When I restarted later this evening the blue LED did not even flash, it went straight to lock...nice. So the big question is, what is the difference between shutting down the power for 10 seconds and shutting it down for 10 minutes? When shutting down the power before for 10 seconds I still had problems. And the other big question is what is causing this to happen. I certainly don't want to have to be doing a power reset in the middle of a DX contact or a contest. Is there something that can improve how stable it is to prevent this in the future? THanks and 73 Greg AB7R0
Greg. If it happens again, please open a HelpDesk ticket so we can do a one-on-one triage of your issue.0
Thanks Tim. I had one open with Dudley already but I think I can go in and close it now.0
- 245 Community Topics
- 488 The Flea Market
- 7.3K Software
- 327 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 221 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 809 Third-Party Software
