Can a 2N2222 transistor handle PTT switching on the Flex 6500?
Arnie
I am seeking a solid-state answer to PTT switching and wonder if anyone can tell me if a 2N2222 can handle the current? Tnx es 73 de Arnie W8DU
Arnie, If your talking about the PTT signals going into the Flex 6500/6700, the answer is yes.. Al, K0VM0
Thanks Al. Yes, I am talking about the PTT line that puts the radio in transmit mode when the line is taken low. I want to control that line with a 2N2222 if it can handle the current (Am not sure what the current requirment is, hence this inquiry). I am not talking about amplifier switching. 73 de Arnie W8DU0
Yes, that should work fine. AL, K0VM1
Great transistor, some of them can take an amp of current.1
Arnie, Yes, with room to spare. 73, Ray, K9DUR2
From the 2N2222 Datasheet: DESCRIPTION The 2N2219A and 2N2222A are silicon Planar Epitaxial NPN transistors in Jedec TO-39 (for 2N2219A) and in Jedec TO-18 (for 2N2222A) metal case. They are designed for high speed switching application at collector current up to 500mA, and feature useful current gain over a wide range of collector current, low leakage currents and low saturation voltage. I assume this is for the TO-18 metal case, but the plastic case version will also cover any switching the 6000 series has except for amplifier switching.2
- 654 The Flea Market
- 384 SmartSDR API
- 51 Aurora
- 967 Maestro
- 938 Genius Products
