DSP
NR, NB, and ANF do not seem to be working. David
Welcome!
  • Member ✭✭
    edited September 2017
    Seems that way to me as well.
  • Member
    edited February 2017
    smart sdr 0.15.13 -- Yes it seems that NR, NB and ANF do not appear to be functioning properly (if at all). I was hoping the NB recovery would be fixed in this addition. I also noticed that when changing the NB slider, it disengages the NB.
  • Member
    edited April 2016
    I see the exact same problem.
  • Member ✭✭✭
    edited January 2020
    I see the same here.
  • Member ✭✭✭
    edited June 2020
    after two reboots , my DSP is working but not to the degree as 0.13.10 Jim WU5E flex 6500
  • Member ✭✭
    edited March 2015
    Yup - confirmed. Just tried to use them and seems to make no difference.
  • Member ✭✭
    edited March 2015
    After a power recycle of the radio...I now have what seems to be a working NR, but NB and ANF seem to be ineffective.
  • Member
    edited February 2016
    I must need the secret decoder ring. If I am in USB and cram the NR to 100 and engage it I get ANF, which will notch a cw signal. However if I flip to LSB and move passband over the cw note and engage NR I get little or no notch. Obviously the controls are mislabeled and do not work correctly .I can not see any effect of the other 2 DSP controls. Wow 4 weeks since ver 13 release and all those Alpha, Beta, black box and gray box testing and this is what we get. Jeeez. 6700 win7 64 bit hp laptop Duffy NA5MM
  • Member ✭✭
    edited June 2018
    Flex 6700... DSP_ NR - NB -ANF Not working, no matter how many time I shut off the radio or computer; but they can be grabbed and slide on CW or LSB.
  • Member ✭✭
    edited March 2015
    Ok, so as reported below...NR seems to be working...as ANF.
  • Member
    Tried Rebooting radio and computer several times and still no NB, NR or ANF (at least on SSB). Other aspects of this release seem to be improved. Flex 6500, SmartSDR 0.15.13, Windows 7 Ult 64 with Intel based computer -Mike
  • Member ✭✭
    edited March 2015
    I never saw them working in 0.13.10 so they are working the same for me.
  • Member ✭✭
    edited December 2014
    Tuned in a steady carrier signal and NR does seem to knock it down
  • Member ✭✭
    edited June 2019
    NB totally busted here...bummer
  • Member ✭✭✭
    edited December 2017
    havent been able to notice where these controls are having any effect at all.
  • Member ✭✭✭
    edited March 2017
    CW NR - with 0.15.x NR is acting like an Automatic Notch Filter. Easy to demonstrate: - Tune in a steady carrier - engage NR - carrier will disappear in a few seconds - goes faster with a higher NR slider setting Happens every time here....if this is a consistent finding, doesn't it seem like this should have been caught in one of the earlier testing stages? Maybe this is only happening in a few cases???? In any event, It sounds like this should be added to the "regression test case list." Regards, Al / NN4ZZ
  • Administrator, FlexRadio Employee admin
    edited March 2017
    Thanks to all who have reported issues with the DSP. We tracked this down to an issue with our production release build process. The DSP will be fixed in next SmartSDR for Windows release.
