CW Mode ATU cuts receive audio
George KF2T
Member ✭✭✭
Possible new bug: ATU tunes properly when in CW mode (thank you!) but upon "Success" there's no receive audio. Changing mode from CW to SSB and back cures the problem. Using Version 0.15.13 (Windows 8, 64-bit) Flex 6500
Same here with 6500, but if I hit a "dit" all is OK.1
Same thing here. I hit the tune button and receive was ok.0
I noticed the same thing with the 6700. In order to receive I need to click tune then it works okay. No key clicks tones, transmit clean signals.0
forgot to add that after hitting tone I then need to click on MON to listen. The mode switch does not change once set to CW.0
Yep, does same thing here. Recover by hitting key or tune button. 73, Ray, K9DUR0
I have entered this behavior as a bug report in our bug tracker. Thanks to George who reported it and Ray who confirmed it.0
This defect will be corrected in SmartSDR v0.16.x0
- 247 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 772 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 372 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
