Low power on 10 mtrs
WA6FXT Mike
WA6FXT Mike Member ✭✭
Operating on 10 mtrs, for the first time, I noticed that maximum power is only about 70 watts. I verified the output on my Daiwa meter and it matches the Flex6700 indication. I have not checked all bands; however, 40 and 20 mtrs will output 100 watts. Any ideas?
  • Stu Phillips - K6TU
    Stu Phillips - K6TU Member ✭✭
    edited May 2020
    Mike, No problems with my unit - full power on all bands. Forgive the obvious question but have you tried checking the SWR or using the ATU to see whether that helps? Stu K6TU
  • WA6FXT Mike
    edited June 2017
    No problem, Stu. SWR 1.2:1 and the ATU does not help.
  • Dudley-WA5QPZ
    Dudley-WA5QPZ Inactive Employee
    edited March 2018
    Check the total current draw on 10 meter in tune at full power verses the other bands. If the current drawnn at 100 %. Output is less on 10 meters as compared to the other bands, say 15 then it might be a calibration issue, but if the total current is about the same, maybe be in the PA filtering .. Let us know on the Help Desk .
