No antenna, S5 signal on 10mhz. Is this the GPSDO?
K6OZY
Member ✭✭✭
This is an internal 10MHZ. signal generated within the F6.7K. When connecting the antenna, the internal signal drowns out WWV, so I cannot use WWV at 10MHZ for calibration. I checked this with my GPS off, no antenna connected to the GPS. (Will get the GPS antenna up when I get a longer cable.) I am not sure what the calibration procedure is with no GPS when you can't copy WWV. Version 0.13.100
Probably WWV I disconnected the antenna totally and also connected a dummy load. At times I could see the WWV carrier at S4-5 but the modulation was in the noise and unreadable though I could see the modulation spikes if I looked carefully. Other times I could just barely copy WWV with only a short unterminated coax. It's nice having a really great receiver.0
Very interesting. On my 6500 with a GPSDO I have no problem copying WWV at 10 Mhz with antenna. Without antenna I can still just barely hear it about half the time. Located in SC.0
Anyone from Flex able to comment on this?0
I have not seen a problem with receiving WWV at 10 MHz in Austin.0
This is not an issue with receiving WWV with an antenna attached.. My question is about why I am receiving an S5 carrier on 10mhz without any antenna attached. I don't see how that is WWV, as none of my other radios behave this way (Flex 3000, Flex 1500, Elecraft KX3).0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
