Back Panel PTT
DonS
Member ✭✭✭
I can not key the radio from the PTT connector on the back panel of the 6700. Is this jack active all the time or does it have to be enabled? I have no problems keying from the Mic jack. Don - kx9q
Don, The RCA PTT port on the back of the 6700 is always enabled and works fine here. Mack W4AX0
After further investigation, it turned out to be a bad adaptor - 1/4" to phono. That just ruins the whole day!0
Better that than a defective port on the rig! Glad you could trace it down.0
Just hate it when that happens and yes better that than a defective port.0
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
