Back Panel PTT
DonS
DonS Member ✭✭✭
I can not key the radio from the PTT connector on the back panel of the 6700. Is this jack active all the time or does it have to be enabled? I have no problems keying from the Mic jack. Don - kx9q
  • Mack
    Mack Member ✭✭✭
    edited June 2019
    Don, The RCA PTT port on the back of the 6700 is always enabled and works fine here. Mack W4AX
  • DonS
    DonS Member ✭✭✭
    edited January 2020
    After further investigation, it turned out to be a bad adaptor - 1/4" to phono. That just ruins the whole day!
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    Better that than a defective port on the rig! Glad you could trace it down.
  • DonS
    DonS Member ✭✭✭
    edited August 2013
    Just hate it when that happens and yes better that than a defective port.
