My flex control moves with 150 unit increments instead of 50.
tompanderson
My flex control with my 7600 moved 50 units at a time (I've had the radio and flex control 5 days. Now it switches 150 units at a time when means depending on where you start, you may not be able to tune an integer. Help! FYI, the wheel came loose and I was using it without the wheel. I assumed that was the reason it switched to 150 -- I was turning it more degrees with the stem than with the wheel. I reinstalled the wheel and it's still 150. (tiny allen wrench required). Thanks, Tom
I get 50hz on am and ssb, 10hz on cw.0
Mine has only been SSB0
Can you give me the sequence from power up so I can try to duplicate the issue? Do you get 150 hz movement with a mouse wheel, or when you move the cursor with the mouse?0
- 650 The Flea Market
- 154 SmartSDR+
- 50 Aurora
- 964 Maestro
- 938 Genius Products
