rx pre-amp
W5XZ - dan
it sure is nice to have a pre amp available on the low bands, with low gain, directional receiving antennas...one more external box i can get rid of...
They are nice to have, but if you use them on the low bands it will degrade the SNR. Unless you are in a very quiet location (and most of us are not), you should only need to add RF preamp gain on 12 10 and 6m. Refer to this Community post by Gerald. http://community.flexradio.com/flexradio/topics/when_do_i_need_to_use_the_flex_6000_rf_preamp0
indeed...without a good preamp..many of the RX only antennas just wouldnt play on the lowbands or anywhere else. Since I know Dan is an avid Lowbander and gives a good endorsement to the internal preamp of the Flex (must have very low self generated noise?) I was happy to see his post.0
I have used the 6500 enough by now to know that with an efficient antenna, the preamp is rarely necessary, However, with an inefficient antenna it is more likely that using the preamp would be benificial.. An inefficient antenna likely means that the inefficiency is also applied to the potentially overloading signals as well as the desired signals. ( and, of course, to the transmit signal ). Two cents worth. AL, K0VM0
- 248 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.5K Radios and Accessories
- 773 Maestro
- 42 FlexControl
- 727 Genius Products
- 252 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 373 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
