Amber LED but no GPSDO option
John Stuart KM6QX
The Amber LED is on when my 6700 (without the GPSDO option) is turned off. The Radio Setup / GPS / Uninstall 'button' has no effect, but the Install button does produce this "GPS is currently installed" message. So, the front LED and SetUp message indicated that I have the GPSDO option, but I do not. 6700 v0.13.10 John Stuart, KM6QX
I have the same issue with my 65000
You must access the Radio Setup from inside SSDR. Click on settings and then Radio Setup. Then the uninstall should work. That's what worked for me.0
Thanks Art, I had tried that sequence several times (I swear) but I tried it again, but this time clicking "Uninstall" three-times with my fingers crossed, and, , , it worked! John KM6QX0
I have entered this behavior as a defect in the developer's bug tracker for additional investigation. Thanks for the report0
This issue has been fixed in the SmartSDR v0.15.x and greater releases.0
- 250 Community Topics
- 488 The Flea Market
- 7.4K Software
- 330 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 344 SmartSDR API
- 8.6K Radios and Accessories
- 774 Maestro
- 42 FlexControl
- 729 Genius Products
- 253 Tuner Genius XL
- 84 Antenna Genius
- 224 Shack Infrastructure
- 151 Networking
- 374 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
