Fused power connection
Dale KB5VE
With the cable supplied there is no fuses. Is there internal fuses? If not what should the power lead be fused at.
As I kunderstand it, the 6K is fused internally.. Whether You wish to include an external fuse may depend on you power source and distribution system.. If your running from something like a battery or a power supply that does not include internal current limiting, then you want a fuse at the source.. If your using a recent vintage power supply, that can survive a shorted load,, then a fuse may be unnecessary. AL, K0VM0
There is a 30A internal fuse for the entire radio and another 3/5A fuse for the receiver-exciter board. With PowerPoles most people are using a distribution box that fuses each radio at the distribution point. You may, of course, place a fuse in-line with the power cable as well. Steve1
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
