popping sound in received audio
W5XZ - dan
this seems repeatable; 6500, cat5 straight to shack pc; win7 64 bit; 12.17 software; band 160m; mode cw; agc fast; AGC-t 41; filter 3 khz; after the rig has been on for about 10 minutes, i can hear this 'popping' sound; not loud, but audible; almost sounds like powerSDR when the audio buffers were too small, but less frequent; random timing from 2 to 15 seconds between 'pops'; lasts about 15 minutes, then goes away... no other activity on this pc.. just me? 73, W5XZ
3
I see this as well; I thought that this may be part of the audio issue that was in the works to be resolved in an update? I have close to the same layout as Dan but with different settings: 6500, cat5 into adapter; win7 64 bit; 12.17 software; band 80 & 20; mode SSB; agc MED; AGC-t 25; filter 3 khz. 73's Joe WD5Y0
I have noticed this same thing here on my 6700. AGC mode and filter width make no difference. I see it most of the time on cw but have heard it occasionally on ssb. Seems worse on very strong cw signals. Very annoying and loud especially on earphones that have good high frequency response. It does seem to get better after the radio has been on for 30 minutes or so. 73s Jim K4JAF0
The popping is actually the codec dropping the occasional sample. There are some major improvements in the upcoming version of SmartSDR that should mitigate this behavior.2
Thanks Tim... Look forward to the next version of SmartSDR. Maybe this week? 73s Jim K4JAF0
good deal Tim...a nice clean audio chain clearly differentiates these rigs from most others, IMHO..." Grandpa, what's a crystal filter ?? "....0
nice job, John!! I bet new gear has never been tested this thoroughly...by end-user consumers...0
Tim, is this also a problem with f3k ?
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
