GPS Time on SmartSDR screen
I agree that this would be a very nice feature. But I also agree that we need to get 1.0 on line first. Al N4AB1
Al, If you agree, then make sure you click on the "Person Likes this Idea" button in the post to vote for it.2
I agree that it is a great idea, but not critical for release 1.0. Also, is there a way to make that time figure available to the computer's OS in order to automatically set the computer clock from it?1
The technical answer is yes, but the question is, do you want to consume radio CPU cycles that could be used for radio specific applications just to feed the PC data it already gets on it's own from the Internet? With finite resources in the radio, there is always a trade off because the first rule of thermodynamics applies; you don't get something for nothing.0
Thanks for your answer. I am a dreamer, always thinking of things that COULD be, but not all of them are practical. I was thinking in line of an option that could be turned on or off at times when internet time servers are unavailable (portable operation, etc.) perhaps for a few seconds to set the clock and then turn it back off. But you are correct, some options take more CPU / memory / programmer effort than would be practical.1
Depending on radios internal overheads it might save some clutter. In some field locations there is no Internet access. So GPS timing is needed for some digital modes. But as I can do this already with a Bluetooth GPS unit it's not a big issue. Andrew0
Maybe the DaVinci OMAP processor on the 6000 series could run an ntp server under it's Linux-based OS that ultimately gets it time from the GPSDO module, if equipped? That would allow one to easily set the PC time based on the GPSDO.0
An NTP server is not hard to do -- it's just not risen up on the priority list yet. I would recommend adding a new idea topic for this so it is not lost in the GPS time on SmartSDR screen topic. Then others that want this can like the idea and we'll know how much interest there is for this idea.1
This is now user story US1907. Update: This has now been implemented and will be in 0.16.x (out soon) and later versions of SmartSDR. I'd like to know what you think of the implementation. Be sure to check the GPS tab under settings as well as the front panel indicators. Here is a screen shot of what it looks like including the GPS data on the settings panel and the lock indicator/grid square in the lower right of the main SmartSDR window.2
What exactly is a "user story"? Is the idea on some sort of internal list to be programmed in the future? Thanks Jim0
A user story is a feature request in the parlance of the Agile development process we use for creating software http://en.wikipedia.org/wiki/Agile_software_development0
Supposedly, I paid for the GPS option. I got an antenna, there is a shiny gold male **** on in about the middle of the lower back. I think I see the start light go through the warming up process, but SmartCat never seems to connect to the antenna. I am in the basement and the antenna is still inside, at about ceiling height. Do I have to move the antenna outside? It doesn't look like it will survive a chicago winter outside.0
Quick question.... will there be a chance that an NTP server implementation will be added to the radio at some point - to query on port 123? I did not buy the GPS option as I really did not have the need - but if the radio could possibly be used to provide NTP time I would definitely be ordering the GPS option. It would be of more use due to it's multi-role and cheaper than some of the dedicated GPS NTP boxes out there.0
This GPS antenna is working well for me: https://www.fairradio.com/catalog.php?mode=viewitem&item=8953 It's mounted outdoors at the base of my tower through 100 feet of LMR400. If you have a surge suppressor on the feedline, make sure it can pass DC.0
NTP has been often requested and it is fairly easy to do so the chances are high that we will do this in the future.2
Great. Thx.0
I'm confused by this thread (and many other things). Is the time displayed on the GPS tab of the radio setup from the computer's time or the GPS' time? If it's the GPS time, wouldn't that mean that the GPS time is available in a data packet from the radio? Is so, it should be simple (for someone) to interrogate that packet and set the computer's clock to the GPS time?
Similarly, what is the source of the time displayed on the main SSDR screen?0 -
Hard to tell which time is which, when they all read the same.
In my case the PC clock is disciplined by Meinbergs NTPD daemon synced to a stratum 1 clock source. and the time displays on both the GPS tab and on the SSDR status bar, always seem to agree on what the correct time is. The GPSDO might be the reason, or they may all be reporting the PC clock time.
An old Chicago lyric ...
"Does anybody really know what time it is?"
"Does anybody really care?"
Well some of us seem to.
73, Jay - NO5J0 -
Mark - the time shown in the bottom bar of the SSDR console is based on the PC clock and the configured time zone to calculate GMT. The GPS time is independent.
"...wouldn't that mean that the GPS time is available in a data packet from the radio? Is so, it should be simple (for someone) to interrogate that packet and set the computer's clock to the GPS time?"
This is the NTP or SNTP protocol defined by RFC 958 (https://tools.ietf.org/html/rfc958). We could do this in the radio and use the GPS as the time source to create a stratum 1 host. As Steve noted, this is something we are likely to do in the future.
NTP would be a welcome addition.
k3Tim
My vote is for the NTP option. Al, N4AB0
I'd prefer the NTP option too, I would really like to have a stratum 1 host in the shack. If it's only on the round2it list for now, at least it's on the list. It will make a nice surprise in a future release.
73, Jay - NO5J
I want to know how Steve got his Flex going 61kts?0
Would also be useful to know the vector. We might be able to determine where he's going, and when to expect arrival.
73, Jay - NO5J0 -
He was in the car coding while traveling to go on vacation. Lori was driving.0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 746 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
