phase reversal between audio channels
N4AB
I was listening to W1AW code practice on 40 meters using 2 slices tuned exactly the same, except one slice was on the left speaker the second slice was on the right speaker (also using a headset). Seemed to work well. I then changed the L/R slider to the center for the left channel and noticed a decrease in the volume which I could reverse by going back to the left position. I tried the right channel slider with the same result, a marked loss of volume. The next step was to move the slider all the way to the left to match the other slice. The result of both slices on the same audio channel (left of right) was the almost complet cancelling of the W1AW signal in the output. I guess my question is, could there be a phase reversal (180 degrees) between the audio channels? And if there is, should there be? Don't really know why I was listening like this but at the moment it seemed OK. You guys are doing a great job, under very trying conditions. Thanks. Al N4AB
Al, We have identified there is a situation where the audio phase reverses and the resultant behavior is as you described: Left goes to Right and vice versa. The engineering team is hot on the trail of this along with several improvements in the audio area. We hope to have this one tackled in time for the 1.0 release. Thanks again for the report! 73, Greg1
Greg, it is not the switching between the left and right channels that I have also noticed before. This problem seems to be an actual 180 degree change in the two audio signals where one cancels the other out. not a swap in sides, that leaves the volume the same. This problem actually reduces the volume of both channels esentialy to zero. Sorry I forgot I'm using a 6700 with GPS and Win 7 Al N4AB P.S. Why are you still working, its 2240 there.0
Greg, I have tried several times this morning to repeat this situation but since I rebooted the 6700 last night I can not repeat the action. Hopefully a one time thing or more likely something I was screwing up. 73 Al N4AB 6700 GPSDO Win 7 HP I7 laptop with 2nd monitor0
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
