Remote Flex-6600 + LDG RT-100 auto-tuner + Palomar Engineers BAS-71 w/9:1 UNUN
Our remote Flex-6600 has a built-in tuner but our antenna sometimes exhibits high VSWR. Although the FLEX' internal tuner says that the antenna is "tuned", we are concerned as in certain spots it starts at way over 5:1VSWR, while the built-in tuner is not supposed to be able to handle that … but it is.
Here is what we want to use:
Flex-6600 (internal tuner off) —> DC injector (to power the tuner) —> coax to the tuner —> LDG RT-100 auto tuner at the antenna connection point —> Tuner output to the Palomar Engineers BAS-71 antenna input, which has an internal 9:1 UNUN —> antenna wire & coax counterpoise.
The RT-100 auto-tunes on RF and memorizes most settings. There is a remote reset which we will control via on of the relays on an MHCOZY controller. I use a RT-100 at home with an IC-7300 and I only had to use the reset button when I changed antennas
Has anyone used a similar configuration? More specifically using an external auto-tuner like the RT-100? Any caveats, suggestions?
Hi Bruno, the ATU in the Flex is conservatively rated for a 3:1 mis-match. Any given amount of resistive or reactive mis-match over that will often work just fine. The ATU in the Flex at my club station tunes an end-fed antenna on bands it was never designed to operate on.
I have not used the setup that you describe with the LDG tuner.
Thanks for the info Len
One reason I ask as that our 6400 wound-up TXing ~50W-60W max, even into a dummy load. After help from Flex Support, we were asked to send the club's Flex 6400 for repair. It's currently in their service queue with an ETA of around August 8-13. At that time we should hear what was the problem and the possible cause.
We replaced the 6400 with a 6600M that was dotated to our club. However, I want to make sure that the antenna mismatch was not the cause. The 6400 had excellent audio and everything worked fine. However, it could not get more that 50-60 Watts depending on the band, and that even into a pro-quality BIRD dummy load. The temp 6600M shows 100W+ into the dummy load and into the antennas.
All this to say that IF they report back that the problem is in the tuner area, or caused by mismatches, then we don't want to "break" the 6400 or the 6600M radio. So if the cause is related to the antenna/PA, and if they point us to VSWR, then the "plan" would be to use an external auto-tuner. It needs to be auto as the radio is at our remote repeater site on Palomar Mountain. No easy or quick way to get there, especially in the winter and Flex's 3rd-party tuner is way too expensive and overkill for our club. We have one radio @ 100W, and two antennas :-)
- 694 The Flea Market
