Toggle TX Power when AMP Power Genius Engaged
Sherman Banks
Sherman Banks Member ✭✭
When operating SmartSDR with the Power Genius amplifier on standby I like to run 100W. It would ne nice if SmartSDR would lower the radio's power when the AMP is brought on line. Currently I have to manually lower the power each time. SmartSDR should remember the proper radio power setting you last used on each band so you won't accidently overdrive the amplifier.
1 votes
Active · Last Updated
  • David Decoons, wo2x
    set the proper drive level for each band in TX Band Settings and create a new TX profile called QRO.
    then create a new TX profile called 100W and set TX Band settings to 100 watts for each band.
    Then you can create two separate global profiles. One with the QRO profile(proper drive levels) and other with the 100 watt TX profile.
    now just select either QRI or 100W profile.
    I believe that FRStack can do that for you. You'll have to download the program and configure it.
