Cat not working in WXJT-X
Trying to configure wsjt-x on my 8400M. W9NWR and I worked on it for 2 hrs this morning and it keeps saying rig control error. we followed the guide that Ken Wells put out to the letter but still does not work. When I try to test it with the test button, it says rig control error. Any suggestions.
  • Erik Carling EI4KF
    SmartSDR CAT + WSJTx configured on same port (yours will say Slice A). The port parameters are Protocol = CAT, Type = TCP.
  • KB4OIF
    KB4OIF Member ✭✭
    Mine says 9600 baud rate. CAT is checked under PTT method. We went by Ken Wells guide when we set it up.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Baud rate is irrelevant for a TCP connection.
    Baud rate is irrelevant, only applies to serial ports and not TCP ports.
  • KB4OIF
    KB4OIF Member ✭✭
    Forgot to mention that when we were testing, the was 2 A slices on the display. don't know if that would help.
    edited July 30
    If you have more than 1 slice, then is uses a different CAT port (RS232 or Network).
    I have a number of videos onhow to do it on YouTube. As there are many ways, they are all correct.
    The key part depends on which version of SmartSDR you use and that will dictate which Audio Input and Output device you use.
    Here are the key parts:
    • CAT control - how to communicate with the radio for frequency and band information. FlexRadios can use several CAT protocols, either FlexRadio or Kenwood. Using a Kenwood TS-480 as the radio in WSJT works.
    • PTT - Today, it is now part of CAT control so you want to say PTT via CAT on the radio setup screen. Stop here and hit the CAT and PTT Tests. If this doesn't work, stop here and resolve it.
    • RX Audio - FlexRadio have multiple audio paths starting at number 1. In SmartSDR you need to assign the slice (VFO) you are using to a number and for those of us just starting, number 1 is a good choice. Next, in WSJT Audio, you need to pick the one DAX RX 1 so that WSJT can hear the audio from the radio
    • TX Audio - this is how you send the audio to the radio when in transmit.
    I would watch the one for SmartSDR v4.2 and up first.
    Feel free to ask more questions and we can get this sorted out for you.
  • Geoff AB6BT
    Just curious, how can you have 2 A slices?
  • Chuck1
    Chuck1 Member ✭
    Hi Geoff and all,
    I was trying to help John get up and running on wsjt-x. Followed Ken Wells instructions. I have a AU-510m and set up mine according to the same instructions, works perfect. John set his up the same as mine. I think he has a 8400. His rx is working just fine but fails Cat Test within wjst.
    He has two A slices (nope, don't know how that is possible) and I wonder if that is somehow tied to the Cat failure...grabbing at straws here...
    Do you folks think a rig Reset is the next step and start over. I wonder if the double "A" is causing other unknown issues. I think that needs to be resolved first.
    I am stumped.
    73 Chuck, W9NWR
    @Geoff AB6BT
    WSJT can support multiple slices by having multiple WSJT profiles. It takes a bit of manual editing.
  • Geoff AB6BT
    Mike…Yes I have that working. But how do you get 2 A slices???
    edited July 30
    You can't on the same Client. Why do you need 2 A slices? Sorry, I must have miss explained something. :)
  • Chuck1
    Chuck1 Member ✭
    Hi Mike,
    That is one of John's issues, he does have 2 slice "A" showing from what he tells me. I assume that is not normal? We were doing a plain vanilla wsjt-x set up, had a failed CAT Test, and ran across these two A slices.
    Wanted to resolve the two A slices and then get back to the failed CAT Test within wsjt-x.
  • Geoff AB6BT
    From John:
    "Forgot to mention that when we were testing, the was 2 A slices on the display."
    Two A slices are because there are two GUI clients connected at the same time (multiFLEX). My guess is that the front panel is one of those GUI clients.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    On an M model, the front panel is one of the two multiflex clients. The other client is probable the pc used for WSJT. Each client gets a slice A. A Maestro and a PC or two PC's work the same way.
    I would like to see the screen shot of 2 Slice A's on the same client.
    You can have 2 Slices A's when using MultiFlex but you can only assign DAX and CAT to one of the clients, assuming it was something like SmartSDR and a Maestro or M Model.
    This is why there is this station selection. That is the name at the bottom of the SmartSDR screed, which you can edit by clicking on it, or under the Maestro TAB in Settings "Station Name"
    Hopefully, that answers the question and outlines the limitation.
  • Geoff AB6BT
    MultiFlex must be the case but it certainly was not clear in John's OP.
  • Chuck1
    Chuck1 Member ✭
    John informed me that his Multiflex is disabled. He will try to work up a screen shot and post it.
    He has bad storms now so it will probably be tomorrow.
    73, Chuck w9nwr
    On Windows, use the Snipping Tool or built-in keyboard shortcuts:
    Snipping Tool (best for editing/annotating)
    Press Windows key + Shift + S. Your screen dims and a small toolbar appears at the top letting you choose rectangular, freeform, window, or full-screen snip. The capture goes to your clipboard, and a notification lets you click through to annotate and save it. You can also open the Snipping Tool app directly from the Start menu for more options (delay timer, etc).
    Keyboard shortcuts
    • Windows key + PrtScn: captures the full screen and automatically saves it to Pictures > Screenshots.
    • Alt + PrtScn: captures just the active window and copies it to your clipboard (paste with Ctrl+V into Paint, Word, email, etc).
    • PrtScn alone: copies the full screen to clipboard without saving a file.
  • KB4OIF
    KB4OIF Member ✭✭
    here is the screen shot. also error message. finally got clipboard to work right.
  • Chuck1
    Chuck1 Member ✭
    Hi John,
    What happened to Network Server in WSJT? Its blank from the looks of it.
    Chuck,
    w9nwr
  • Geoff AB6BT
    Sorry, I don't see the 2 A slices. Perhaps a screenshot of SSDR?. I'm realy curious…
  • KB4OIF
    KB4OIF Member ✭✭
    I may be confused Geoff. one on the waterfall and 0ne on the right hand side panel
  • Geoff AB6BT
    OK, the both of those refer to the slice A in the top panadapter.
    You do have another panadapter open below the A slice panadapter.
    For now to make things simpler, just close the second panadapter by clicking the "X"
    marked here:
  • KB4OIF
    KB4OIF Member ✭✭
    Thanks Geoff. Chuck and I found the problem and it is working correctly. Somehow Network server got deleted. after it was put back in, things are working now. thanks everyone for your thoughts and help.
