Enhance winkeyer commands to allow sidetone control for SO2R
n3oc
n3oc Member ✭✭
This is badly needed for better use of a single radio for SO2R without a separate controller. The current winkeyer command set supported in the Flex is very basic. Please consider adding the needed commands so N1MM can properly select no sidetone, sidetone or paddle-only sidetone.
Right now there is absolutely no viable solution to paddle-only sidetone which is essential for 2BSIQ operation. This forces everyone back to using a SO2R controller with two radios, which defeats the purpose of having a Flex with two SCUs!
4 votes
Active · Last Updated
  • Eric-KE5DTO
    Can someone describe technically what needs to change in order to implement this? Are there specific Winkeyer commands?
  • n3oc
    n3oc Member ✭✭
    edited July 23
    Yes, it happens during the initialization of the winkeyer emulator. Some of this SmartSDR is probably already doing. N1MM is sending it some initialization commands, not sure how much the Flex winkeyer emulator is honoring.
    What's missing is N1MM sends 01 88 (sidetone freq 500, paddle only sidetone) and SmartSDR ignores it (I think)
    When paddle-only sidetone is not checked, N1MM sends 01 08 in the initialization which seems to be regular sidetone with a freq of 500 (not paddle-only).
    I don't really care about changing the sidetone freq too much, that can still be done in SmartSDR, but it is important to be able to distinguish between N1MM telling winkeyer paddle-only sidetone and SmartSDR honoring the request, which would be no sidetone for winkeyer generated CW, but produce sidetone for paddle-generated CW (and even CWX generated sidetone is probably OK, just need it to stop for winkeyer because in 2BSIQ the op is busy listening to CW from the other slice and can't have sidetone from the transmitting slice interfering).
    Some of the source documents are here, in the immediate commands section. The docs show it in decimal, it is probably really send it hex.
    https://www.k1elsystems.com/files/WK3_Datasheet_v1.3.pdf
    What are the implications for remote SmartSDR generated paddle CW? Seems like it would be similar, I think the remote SmartSDR is generating the sidetone, would need to not generate sidetone for winkeyer sent CW if that command is received from N1MM, not sure if the winkeyer emulator is located in the radio or in SmartSDR. Maybe not as hard as it sounds if the winkeyer emulator is in SmartSDR.
    Brian N3OC
  • n3oc
    n3oc Member ✭✭
    edited July 24
    Also, being able to control keyer speed independently from winkeyer and paddle is highly desirable. The winkeyer spec has a setting for that too, use winkeyer speed potentiometer for paddle and keyboard cw only. So probably need to accept winkeyer speed commands from N1MM and move SmartSDR keyer speed accordingly. That command is set wpm speed 02 xx and change speed buffered 1C xx.
  • Eric-KE5DTO
    We're tracking this as SMART-13047. Thanks for the additional info.
