SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
8400M Profile Settings
There is a Global Profile and the two choices are:
SO2RDefault or just Default
The TX Profile choices are:
SO2R_TX1
SO2R_TX2
Default
I do contest and I use N1MM. I also will use both slices A and B for a contest.
What should my profiles be set to for the Global as well as the TX Profiles?
Thanks for your help.
Mark Griffin, KB3Z
Hello Mark…Profiles record your personal operating preferences so nobody can tell you what you should do. Set your radio up the way you want then save it as a new profile. If it's not perfect the first time tweak it and re-save.
I have over 25 global profiles for different bands and modes, along with 3-4 transmit profiles and a couple of microphone profiles depending upon where I want to use processing or not. Some might have more, some might think that's excessive. It doesn't matter, it works for me.
Knowing which functions are saved by global/transmit/microphone will save you a lot of time, and that's spelled out in the software manual. Also check youtube as there are plenty of videos related to profiles there.
Happy hamming.
- 419 Community Topics
- 718 The Flea Market
- 228 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
