No audio from DAX voicekeyer N1MM
With using N1MM voicekeyer, after update ssdr, there is no audio coming anymore to my TX signal. By pressing F1, transceiver goes into TX but no .wav , so no audio to be heard no ouput.
Also in JTDX i don't have audio signal coming to my Flexradio
Tnx for any help!
Laurens PD9X
When you say "update ssdr" are you referring to an update to 4.2.x from a version before 4.2? If so, the DAX naming architecture has changed and the channels have new names. For example, assuming you are really on 4.2.x which you do not explicitly state, in JTDX the Input is now DAX RX 1 (FlexRadio DAX) and the Output is now DAX TX (FlexRadio DAX). These will be found in the JTDX Audio drop-down boxes.
Similarly, you must update N1MM.
Check the Flex video, specifically at minutes 9:40 and 10:30
Also, See this article and the links contained therein:
Adapting to the New Version of SmartSDR with DAXv2 – FlexRadio
- 417 Community Topics
- 716 The Flea Market
- 224 SmartSDR+
- 471 SmartSDR for Mac
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 139 Aurora
- 999 Genius Products
- 365 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 149 Contesting
