CW Pitch and Delay
Hi All,
In a logbook I am developping I have a tab for control of the flexradio, the problem is it seems like the pitch and delay of CW is not properly announced by the API it is always 6 00 hz and 5ms no matter if I change on SmartSDR
S5C219C46|transmit sb_monitor=0 mon_gain_sb=80 mon_pan_sb=50 pitch=600 speed=30 iambic=1 iambic_mode=
1 swap_paddles=0 break_in=1 break_in_delay=5 cwl_enabled=0 sidetone=1 mon_gain_cw=35 mon_pan_cw=50 synccwx=1
while in SmartSDR I have 150 delay and 550 hz pitch.
Is there any ohter way to get the accurate value than a sub tx all ?
  • g4ivv
    g4ivv Member ✭✭
    Hello Greg,
    I believe the problem is that your client is not bound to a specific GUI client. In the multi-flex world, you can have 2 GUI clients connected to a Flex radio that each have their own CW parameters.
    It looks like the transmit status messages for non-GUI clients that are not bound to a specific GUI client contain default parameters for the CW pitch etc. Which is misleading and could be classified as an API bug I think. Better would be not to include those parameters if the client is not bound to a GUI.
    73, Jonathan
  • F4BPO
    F4BPO Member ✭✭
    HI Jonathan,
    Interesting, thanks for this info.
    I found the break in delay by subscribing to CWX but could not find anywhere else for the pitch. Gonna look into this biding to a GUI client further.
    The last time I looked at the API Wiki, the bind command was not documented properly. When I get home from breakfast (at a French bakery 🙂), I will post my write-up of the command.
    Jonathan's assessment is correct.
    Here is my description of the bind command. This did not come from Flex; it came from my experience in making it work.
    I hope this helps.
  • F4BPO
    F4BPO Member ✭✭
    Len thank you so much !! I will try this in my logbook to see if it works.
  • g4ivv
    g4ivv Member ✭✭
    Thanks Len for the great write-up of the bind command,
    73 Jonathan
  • F4BPO
    F4BPO Member ✭✭
    All good now working as expected ! thanks a lot for your help Len
    Great to hear! The bind command made a huge difference in the TeensyMaestro. It is more important than most people realize.
