Disconnecting the antenna by closing the active slice on a 6400M
Froemke
Challenge: Finding an easy way for local operators to disconnect the selected antenna after using an 6400M radio.
- Rather than requiring three-taps to disconnect the "M" control panel (Menu>Radio>Switch Versions) is there a simplier process?
- Such as a one-tap process of tapping on the slice letter (usually A) to disconnect the antenna.
Our club station is hybrid in that we have both local and remote users.
- When a local user leaves the "M" control panel active, it ties up one of the clients and the selected antenna thereby limiting what the remote clients can do.
- Yes, the remote clients can force a disconnecting of the local client but, it may be in use.
