Flex-6600 with WSJT-X, wont get TX audio from WSJT-X
ve2dx
ve2dx Member ✭✭
I encountered something similar years ago with 7300?
Audio input is ok, wsjt-x decodes fine.
Radio goes into TX ok, but no modulation (No TX Audio) on the signal
wsjt setup FlexRadio Slice A, 192.168.2.99:60000, PTT=CAT, Mode USB (tried all 3),
Split=None (tried all 3), Test cat ok, test ptt ok
audio; Input= DAX RX 1, Ouput= DAX Audio TX. Tested also DAX TX
DAX: TX Stream Blue, Mic Stream = Blue, RX Streams Slice A = Green.
I just cant get TX Audio from WSJT to the radio???
help
Richard
    Hi Richard, Just to be sure, you have DAX set as your audio source here, right?
  • ve2dx
    ve2dx Member ✭✭
    fixed, rested radio to factory default?
    all ok now?
