Recording all of audio for contest
Hi every one, right now I have a issue about how to record all of audio from PC MIC, DAX TX, DAX RX these three streams from SmartSDR DAX inside the DXLog software on my WIN11 computer. It would be great if you knew and could help me. Thanks in advance.
I don't think you can do this if you have the microphone (or CW key) connected to the radio. Flex radio's don't offer an "audit" audio stream that lets you record both transmit and receive audio in one stream.
You have to route the TX audio to the recording device outside of the Flex radio, so you have do something like connect your microphone and CW key to the PC which then records transmit alongside the RX audio.
For those of us that use SDC contest software, this lack of audit recording was one of the reasons Yuri developed the SDC RigAudio module, so that contest compliant recordings could be made (including support for multiple slices), but that means you have to connect microphone and CW key to the PC running SDC. I suspect similar solutions may exist for N1MM and DXlog.
73, Jonathan G4IVV
I can only select the one of recorder sound cards as following screenshot. If it's a stuation like this, It seems to only record DAX RX of my contest audio(unable to contain PC MIC and DAX TX). I will not be able to record PC MIC, DAX TX, DAX RX at the same time.
Who knows, please!!!😂
- 688 The Flea Market
- 105 Aurora
