Interlock preventing transmission. (Apple IMAC)
KG5PTE
Hello first does Marcus (DL8MRE) provide support for the Apple IMAC version too ? Or does he just support the Apple IOS version ?
Second. I just purchased a new Apple IMAC and installed Flex smart SDR and for the first hour I had no problems with transmitting. But after letting it run for a while the Interlock problem showed up. Now when I press the PTT Interlock is preventing transmission. No on Apple IOS on the iPhone the radio transmit works fine fine. I did a google search on this issue and what I got was that this is a known bug/issue. So I am looking for some feedback from other IMAC users.
Thank you
James (KG5PTE)
Update to my post this interlock issue is also happening on my PC's too. I was thinking this was just with the IMAC.
