Fit and finish of Aurora 520
glider73
glider73 Member ✭✭
edited May 20 in Aurora
The 520 is working fine have a question about fit and finish the case top and bottom appear to have had the finish applied using different techniques or different material the case bottom being much smoother than the than the case top. The case top has the same finish that is on my 6600M. Perhaps the bottom is anodized.
  • wb6jao
    wb6jao Member ✭✭
    I have a AU520-M I received in July 2026. The top and bottom of my case's fit and finish is very close to identical. I guess your radio is from an earlier production run and the case parts were done in different batches?
