PGXL Sampler Check for APD
I’ve noticed an interaction (verified on 8600) between TX in Waterfall and using the sampler in the PGXL. I don’t know if the design was intentional, but it gives the operator a good indicator if APD is getting a sample signal.
-Enable Show TX in Waterfall
-Enable the external sampler in APD
The PGXL needs to be in Operate mode for the APD feature to work when using its sampler. If the PGXL is off or in standby and APD is on, there is no display in the waterfall when transmitting. Turning APD off or switching the PGXL to operate restores the TX in waterfall display. If using the internal sampler, the TX in waterfall display is always shown.
A nice, quick, visual, check if APD has a sampling that it can use.
-73
