Unlock Flex-5000 on CB
KrasRider
Member ✭
Hello. My name is Roman. I'm from Russia.
After my grandfather passed away, I inherited a Flex-5000 transceiver, which I use to broadcast live on YouTube and other video platforms.
Recently, my subscribers asked me to broadcast on the CB band, at 27.190 MHz for Russia and 27.555 MHz for European operators.
When I tried to do this, I encountered a problem: the transceiver was transmitting but not actually producing power. After investigating this issue, I learned that the Flex-5000 needs to be programmed with a special key, which only you, the manufacturer, can obtain.
I'd like to receive this key so I can continue using the transceiver unhindered on the CB band.
Transceiver serial number: 0812-3662 Unique ID: 001C2D04007FFFFFF
I would be very grateful if you could help me resolve this issue. I also wanted to know if I could purchase a VHF unit through you. It's not included, but according to online descriptions, it can be installed.
- 113 Aurora
- 978 Genius Products
- 323 Shack Infrastructure
- 228 Networking
