Command Bar CAT commands
Doug
Can anyone supply an example of a CAT command for use in the command bar? (or a screenshot of your Command Bar setup)
I can launch websites and Apps but have been unsuccessful in setting a CAT command.
Ex: I want a QRP@5watts and full @100. ZZPC 005; & ZZPC 100; from what I am reading. But the do nothing.
What ID 10 T error did I commit?
Doug KD9PK
Hi Doug,
Although the command bar says "Send CAT Command" it really means use Flex API commands!
So you need the following:
I just tested it and those work fine with firmware 4.1.5 (don't think the RF power commands have changed for a while).
Hope that helps,
73, Jonathan G4IVV
Jonathan… THANK YOU!!!
That was the missing secret handshake.
- 688 The Flea Market
- 105 Aurora
