Interlock handling SmartSDR / AG 8x2
dk4dj
dk4dj Member ✭
Hi,
i´m developing a device for controlling the AG 8x2 over LAN. Nothing special. I read the API document and the first tests went well.
My problem is now that my config on our clubstation seems to be something special.
On Port B of AG a Flexradio 6600 is attached and controls the AG during the network.
On Port A is a IC-7300 connected an the switching is done by PTP hardware switch.
We now want to replace this hardware switch by a microcontroller solution which reads the frequency from CI-V and send the necessary commands to the AG.
This is working good. Also a error message appears if the port is blocked by the Flexradio.
If the 7300 assinged to a port before this port is choosen by the Flexradio no TX interlock in SmartSDR will appear.
How can this be solved? I haven´t understand yet how SmartSDR and/or AG will handle this type of informations.
73 de Dirk
PS: Proof of concept for the control device could be found at https://github.com/dk4dj/CIV-AG
