DVK F keys
Kaos
Kaos Member ✭✭
Is it possible to get F1 to repeat the CQ message that I have recorded using the Record function of DVK ?
Also any help getting files from Audacity uploaded into my Flex 8600 with version 4.1.5?
I guess that is two question but any help is welcome.
Al
N7OMS
  • KlausP
    KlausP Member ✭✭✭
    Answer ✓
    Sorry, I misunderstood the part about F1.
    But apparently, the DVK is only designed for manual operation.
    So once again, the only option is external software like Voicekeyer.
    73 Klaus
  • KlausP
    KlausP Member ✭✭✭
    Hello,
    I think the first question refers to Maestro F1. There are many posts on this topic that have so far stated that this is not possible.
    I also edited my DVK files using Audacity and imported them back into Smartsdr. It’s important not to import the entire file after making cuts, but to save only the selected section.
    The file format is described on page 4 of the linked documentation.
    Release Notes SSDR-v4.0.1
  • Kaos
    Kaos Member ✭✭
    Am asking how to get the F1 CQ message that is recorded thru the DVK feature to repeat the message without pressing the F1 key over and over?
    Have two Flex radios 8600 with the upgraded version and 6600 without the 6600 without upgraded version I will be using Audacity to upload voice files.
    ON my 8600 hope to use DVK to record and send voice messages.
    I did go thru the release notes but didn't see any reference to DVK setup?
    No Maestro is being used.
  • Kaos
    Kaos Member ✭✭
    Thank you Klaus I have been using N3FJP with good success but was excited to learn about the DVK. Will look at Voicekeyer as I am always trying to learn.
