TX DELAY
SANTI
Member ✭
I have a FLEXRADIO 8400M and an ACOM1000 amplifier. What settings should I use in milliseconds in "menu" -> Transmit -> General -> "Timings (in ms) RCA TX1"? Do I also need to set "TX Delay" or just "RCA TX1"?
TNX de Santi EA3AVQ ea3avq@ure.es
The TX delay is only required on the port to which you have connected the Acom amplifier.
You can determine the required delay time yourself.
If the PA displays the error “Hot switching attempt,” a delay is necessary.
For my 1200S, a delay of 15 ms is required to prevent the error message from reappearing.
73 Klaus0
Thank you so much, Klaus, for your information and message.
Regards
Santiago EA3AVQ ea3avq@ure.es0
- 684 The Flea Market
