Low power output on a 6400 (~60W in place of 100W)
Cannot get more that 60W of our remote Flex 6400 on Palomar Mountain that's ~2 years old and running 4.1.5
- Tried using SmartLink and Maestro (remote) and SmartSDR on the colocated computer
- TXing into a lab-grade 50 Ohm dummy load - VSWR 1s 1.1:1
- Internal TUNER is bypassed
- Added an external lab-grade power meter between the radio and the load
- DC Input while in RX is 13.6 V (measured using FRSTack 4 and an external lab-grade voltmeter)
- DC Input when transmitting at "full power" drops to 13.2 V
- Yes, we pulled and reinserted the power pole connectors
- Transmitted on 10, 12, 17, 15, 20, 40 and 75m using:
- TUNE (scroll bar set to max)
- CW
- SSB (looking at peaks)
Results:
- All measurements showed a max of ~60W
- Actually showed a range between 54W and 62W depending on the band
This remote radio is being used for voice and DATA, mainly FT8/FT4 and JS8call
- Authorized club users are trained to not go over 40W for data.
Note that when I connect to my much older remote 6400 in Florida, it shows 100W with 13.2 Vdc in TX. So there is something going on with the remote 6400.
Are we missing anything or will we need to open a ticket with Flex and perhaps send the radio for repair?
Hi Bruno, 13.6 is too low. I would turn the power supply up to something between 14.2 and 14.5 volts. I suspect that will solve the issue.
If not, check the internal fuse to be sure that there is no corrosion or dirt on the blades.
Do you have a long power cable, or is your power cable smaller than #10 wire? These can all add up to issues like you are seeing.
Hi Len - Interesting as my Florida 6400 remote starts at 13.6V in RX and drops to 13.2V in TX @ 100W and it has been like this since day one (~4 years now)
The remote 6400 I am talking about as the same DC voltage drop. This was measured using FRStack 4 and a lab grade DC voltmeter at the radio DC input. When installed, we measured the same voltage differential and it was TXing 100W into a lab-grade 50-Ohm, dummy load. Now, that same Flex 6400 can't TX more than ~60W on any band into a 50-Ohm lab-grade load
Same issue into the antennas (R8 and a Palomar Engineers BAS-71) when using the radio's built-in tuner to tweak the VSWR. The load ensures that it's not a mismatch with the antenna.
The PSU is 48-to-13.6Vdc (remote repeater/radio site is all DC) and the PSU-to-Flex cable is the stock Flex cable at around 6 feet. We cleaned the PowerPole connections.
The remote radio is a one and a half hour drive up a mountain (5600 feet level) and we only go there weekends. So we are gathering things to check for our next visit.
So far, our plan is:
- Making sure that there is no current limiter that kicked on in the 48-13.6 Vdc converter
- Checking to see if we can get 14.2-14.5 Vdc output from the converter
Any other suggestions?
… next weekend, we plan on switching out the 48v:12v Converter/PSU and set the voltage at the PSU terminals to ~14.5 Vdc. In the meantime, the radio is working and club members are using it, but at a lower power.
60 watts is down less than 3dB compared to 100 watts, less than half an S-unit.
John - I agree, but the Flex should be TXing 100W on any band into the lab grade 50-Ohm dummy load. This is what I am seeing from my Florida remote. Seems like something is awry if we can't get more than 60W into a dummy load (measured between 54W and 62W depending on the band).
So it's not the "less than 3dB down", but why isn't the Flex-6400 TXing 100W?
Question: As this is occuring on all bands and into a dummy load, and as there is no distortion signal wise, can a "factory reset" be in-line?
I ask as if it was the PA I would expect distortion but everyone says that the audio is great … so I wonder if something is glitched in the radio?
Yes, it was reboited and 4.1.5 was also reloaded, but the power doesn;t go higher. I tried using SmartLink, SmartSDR and Maestro. We alko changed the power supply and the voltage goes from 13.8 to 13.2 in TX.
As for "13.6 V being too low", that's way within Fles Radio's specs and my Florida remote 6400 TXs ~100W with 13.2 Vdc showed on the comuter screen via using FRStack 4.
Hi Bruno, 13.2 on TX will not put out full power. A .6 V drop most likely indicates some ohmic losses in the cable, connectors, or fuse holder.
I turned my Astron VS 70M up to 14.25 V. On TX, that goes down to 13.84 V and gives me a full 100 watts out.
Our club station 6400 was putting out around 75 watts. We turned the supply up to 14.3 and now it produces the full 100 watts.
Hmm … I tried with the Flex DC cable (12 AWG) to lugs. At the power supply, we measure a .4Vdc drop when in TX. I just prepared another cable: 10 AWG w/PowerPole on one end and lugs on the other.
The current 48:13.8 Vdc PSU is old but capable of 35A. We are planning to replace it with two ganged 15A commercial Willmore 48 VDC-to-13 Vdc (nominal) which we will crank up to 14.1 or 14.2 Vdc. Primary power in the shelter is all 48 Vdc from battery banks :-)
Note that my remote in Florida cranks out 100W+ without any issue with ~13.2 Vdc measured by FRStack. The same measured DC on the club's remote Flex 6400 results in around 50-60W into a dummy load. So ~13.2 Vdc seems fine for 100W … at least with my Florida radio.
I reached out to support and they gave me a detailled series on things they want us to do. We plan on doing this next trip up Palomar Mountain where the radio is installed. It is remote and an hour drive up to the 5600 feet line :-)
- 408 Community Topics
- 705 The Flea Market
- 205 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
