Flex remote connectivity issues
sp8s
Hi
I try to use Flex SmartLink with SmartSDR to control my 8600 remotely for the fist time. Before that, I used to use 7610 with SDR Control app (same author) successfully.
I used fiber soft internet here. Even though, my panadapters freeze after 1-2 minutes once the connection is established. I need to reconnect to get it living, bu then - after 1-2 minutes - the same story…
I tested the low bandwidth option in the setting - no improvement.
Is there anything else I could try to keep the connection up? Like longer time out or something?
73!
Stan SP8S
PS. a friend of mine, using MultiFlex, is successfully connected to my Flex for over 2h.The only difference is that it is SmartSDR on Windows
- 322 Shack Infrastructure
- 227 Networking
