No audio output to headphones
I have an 8600 and up to today there has been no problem listenin on my headphones. Today stone cold silence, no settings were changed. What do I need to look at?
Hi Mike, make sure that the little headphone icon in the upper right-hand corner of SmartSDR is not muted and is not at zero volume. Also make sure that the individual slice volume (on the slice flag) is not muted or set to zero.
Make sure that PC Audio is not engaged.
Hi Mike, I have had instances of speaker and headphone audio disappearing, usually when messing with the diversity options.
I found that just reloading the current profile works for me most of the time.
Tom
N9RU
Thanks, the audio settings look ok but I haven't tried reloading the profile. I am using Bose 700 headphones and they could have a problem. I switched headphones to some Bose Ultras I have and I can hear audio but have to turn the slider on the slice all the way up to get "normal" audio levels. The headphone slider is at 100% also.
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
