Linking TX and RX profiles
david_TG9AMM
Hi,
I have an 8400 and have set up several mic profiles with different TX bandwidths.
When I, say, choose a profile to transmit at 4K wide I need to manually then adjust the RX bandwidth to 4K in the slice.
Is there a way to automate this as I move between profiles to that the TX and RX bandwidths match each other?
Thank you!
David
Hi David, you can use Global profiles to do it, but there is not anything else that ties them together.
- 396 Community Topics
- 676 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 327 FLEX-8000 Signature Series
- 985 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 314 Shack Infrastructure
- 219 Networking
- 146 Amateur Radio Interests
