Linking TX and RX profiles
david_TG9AMM
Hi,
I have an 8400 and have set up several mic profiles with different TX bandwidths.
When I, say, choose a profile to transmit at 4K wide I need to manually then adjust the RX bandwidth to 4K in the slice.
Is there a way to automate this as I move between profiles to that the TX and RX bandwidths match each other?
Thank you!
David
Hi David, you can use Global profiles to do it, but there is not anything else that ties them together.
- 995 Maestro
