MSHV Setup for Flexradio 8400M
Good Afternoon Flexradio Community,
I am looking for some help with using MSHV with my Flexradio 8400M. Especially when connecting my radio to the software program in the Options/Interface Control Section. I have read that the program is able to make multiple contacts at the same time. And it could be that I didn't word that correctly either. It would be nice to be able to take advantage of both slices at the same time. And preferably on the same band. Has anyone been able to do this and can help me with the setup? I do have the program Slicemaster. But the only programs it shows is CW Skimmer and WSJT. I do not know how I can add additional programs to choose in Slicemaster.Thanks for your assistance.
Mark KB3Z
Mark,
install MSHV and when you start Slicemaster you will see options which program to use on FT8/FT4. If you choose MSHV Slicemaster will configure it.
73 Boyan
You do not need multiple slices for the multi contacts at the same time function in MSHV.
What you need though is to be on a different frequency than the normal FT8 frequencies.
That is why expedition are calling on 14.090 for example instead of 14.074. In dxpedition mode in MSHV you will be able to select how many different transmit signals you want. It can be 2, 3, 4 or more but your power is being split by the number of signals transmitted.
As far as slicemaster is concerned if it does not find MSHV it is because you probably installed it on a folder which is not the "normal" one. In this case you have to edit the config of slice master and put the link to your MSHV.
- 116 Aurora
- 323 Shack Infrastructure
- 228 Networking
