updated commands for flex control
Hi,
I noticed some commands are not available on the flex control.
for example,
"VOX" on/off is not available - think this would be useful on my remote laptop for travel if i didn't want to bring a lot of other stuff.
PTT would be also really nice (MOX but momentary)
would also be nice to come with a label kit for the available options to change the lighted switches to the new functions you select,
thanks,
MN
2
Hello,
VOX command (and some other) is available, but there is obsolete description in API doc, command syntax is different. Correct part of command string is
transmit set vox_enable=1 resp.
transmit set vox_enable=0
73! Jiri OK2WY
hint: connect to radio by putty terminal and look what radio respond when a button in GUI is pressed..
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
