how to remove DAX from Windows 10?
Good morning,
I have a PC that I no longer use with a Flex, but the DAX drivers keep remaining.
They are interfering with other applications I use for a different transceiver. I want all those DAX drivers and audio options removed, both in audio input/output and in all ports.
How can I perform a complete uninstallation of DAX so that it is truly gone everywhere?
Hi, have you read that?
https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSDR-for-Windows-from-your-PC
Thanks,
I solved it by searching through everything related to Flex and DAS in regedit, and eventually removed all drivers and everything running “under the surface.”
I did find an old link from the FlexRadio forum, but that link no longer existed it was from 2019, so it was already a few years old.I have to honestly say that uninstalling DAX is harder than a virus :-) but I managed to get it done.
- 685 The Flea Market
