Xfinity Gateway randomly turning UPnP off
I have the same problem with Xfinity turning off the UPnP feature after a few days. It is my understanding that switching over to port forwarding is a fix, however, I have not been able to successfully do it. I suspect that Xfinity is to blame for that also, but can't say for sure. My plan is to install a different router and then switch the Xfinity modem/router into bridge mode and simply use it as a modem. I have spoken to a few others who have installed their own router and Smartlink works great for them. I hope it will work for me, but I won't be able to try it for a couple of weeks. Good luck!
I am in Canada, and my ISP (Rogers/Shaw) uses Xfinity. I have my Xfinity modem in "bridge mode" - basically just doing a media-conversion from F-Connector cable-TV to RJ-45 Ethernet data-packets.
I then follow this with my own router / firewall (a Ubiquiti UDM-Pro). It works.
In this scenario, I choose to use fixed-IP addressing, not UPNP. However a different choice of router / firewall may allow you to easily use UPNP with satisfaction.
- 409 Community Topics
- 705 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
